Portable gas hot water showers
Submitted: Sunday, Jun 30, 2024 at 16:31
Tom M16
Hi can anyone please recommend a brand?
Country Comfort any good?
Reply By: Member - Warren H - Sunday, Jun 30, 2024 at 16:53
I've got a Joolca v1. The v2 apparently has fixed the fault of going out in really windy conditions. I don't know if other brands have the same problem. My version needs to recirculate really cold
water to get it to 42 deg. (It was the Warrumbungles in July.) This isn't really a problem you can just fill a jerry can and recirculate until you warm it slightly. Prior to leaving it worked fine with
Canberra tap
water in May and it's pretty much brass monkey temperature year round.
646085
Reply By: RMD - Sunday, Jun 30, 2024 at 21:19
G'day Tom.
I bought a Smartek unit for use with a caravan. Homemade Bracket on van side holds the
water heater safely away from van side, gas supply via hose from Bayonet.
The
water pump draws from the
tank through hose fittings and I made a Y with taps so initially the
water can be sent to return to
tank until the heater gets up to set temp. Then change the inline taps to stop return to
tank and flow to shower. Like others, when the flow is stopped at the shower head, the pump stops, heater stops too, but as soon as flow is allowed to resume the heater relights itself without much drop in temp. ie, soap up and rinse off. Seems good. Other brands may work just as good, but I haven't used them so can't compare. Uses two D cells to initiate spark for ignition.
646086
Reply By: Robertd54 - Monday, Jul 01, 2024 at 20:58
Hi Tom,
My daughter has used a Country Comfort for about 6 months now and is very happy with it after having numerous problems with the Coleman they had previously. They are an Aussie company that are easy to contact and speak to on the phone. I have spoken to the owners several times re changing my shower rose to one that uses less LPM and they have been quite helpful.
I suggest you give them a ring and have a chat re your requirements and any concerns you may have re flame blowing out, lack of hot
water etc as I am sure they can honestly answer them for you.
Rob
646091
Reply By: Brahim D - Wednesday, Jul 10, 2024 at 04:25
Portable gas hot
water showers are a great option for campers, off-roaders, and anyone who needs hot
water on the go. There are a number of brands on the market, but Country Comfort is a popular choice.
Here are some things to consider when choosing a portable gas hot
water shower:
Water flow rate:** How much
water do you want to be able to use per minute?
* **Temperature rise:** How hot do you want the
water to get?
* **Size and weight:** How portable do you need the shower to be?
* **Ease of use:** How easy is it to set up and use the shower?
* **Price:** How much are you willing to spend?
Country Comfort showers are known for being durable, easy to use, and efficient. They come in a variety of sizes to suit your needs, and they can heat
water up to 60 degrees Celsius (140 degrees Fahrenheit). However, they can be a bit on the pricier side.
Here are some other popular brands of portable gas hot
water showers:
* Zodi
* Camplux
* Nemo
* Iwatani
When choosing a brand, it is important to read reviews and compare features to find the shower that is right for you.
646169
Follow Up By: RMD - Wednesday, Jul 10, 2024 at 21:27
I tried finding Nemo. Failed!
926680
Follow Up By: ModSquad - Monday, Jul 15, 2024 at 11:01
Sounds fishy to me RMD!
926704
Follow Up By: Member - Warren H - Friday, Jul 19, 2024 at 09:31
Someone has to be the Clown.
926722
